Activity › Forums › Adobe After Effects Expressions › layer opacity = layers distance from camera
Posted by Jonas Espinoza on January 15, 2007 at 7:05 pmhave some 2.5d layers spaced out in z space, am moving the layers as a group with a null past a stationary camera. is it possible to like these layers opacity to their distance from the camera?
thanks
Mike Clasby replied 19 years, 8 months ago 2 Members · 2 Replies -
Mike Clasby
January 15, 2007 at 8:29 pmThis eperession from Dan works, but not if the layers are the children of your null. Dan probably has a fix for that, but if you want to keyframe position of the layers (or move with an expression) this will work.
startFade = 1000;
endFade = 2000;d = position[2] – thisComp.layer(“Camera 1”).position[2];
linear(d,startFade,endFade,100,0)Explaination here:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=881321
Mike Clasby
January 15, 2007 at 8:59 pmHere’s another one from Dan, better I think as it avoids that seeing through one layer as it’s opacity changes. You’d need to add a light as it works off the layers Specular and Diffuse 3D properties and the distance from the light. Again, not for children of the parent Null.
Date: Aug 24, 2006 at 2:36:30 pm
Subject: Re: Wow. That’s intense. Ok, Thanks! errr…I think I’ll go with Buena-Plugin.A little late to the party, but here’s a fun thing to try. Add this expression to the diffuse and specular material options of your 3D layer:
decay = .001; // speed of falloff
d100pct = 200; // distance from light where falloff beginsL = thisComp.layer(“Light 1”);
d = length(L.position,position);
if (d < d100pct){ value; }else{ value/Math.exp((d-d100pct)*decay); } The first parameter has the most effect on how fast layers get dark as they move away from the light. The advantages of this approach are that the layers don't become transparent and the effect is independent for each layer since the intensity of the light itself is not affected. Dan
