Activity Forums Zaxwerks Layer Map is applying itself to surface 1 on every object
  • Layer Map is applying itself to surface 1 on every object
    Posted by Sean on April 19, 2005 at 4:55 pm
    Of course I know that I’m doing something wrong…
    I made a rectangular box that I’m using for a video screen, but I decided I wanted 3 of them, so I use the duplicate object and made 3 of them. They all can be assigned to diffrent sets and act as 3 independant objects, BUT when I go and assign a layer map on the front surface of the first box, it applies itself to the front surface of ALL the objects. So, Was it because I use the duplicate feature? Should I have made 3 seperate boxes from scratch? Thanks for the help!
    Sean
    Matt Rhodes replied 21 years, 4 months ago 2 Members · 1 Reply
  • Matt Rhodes
    April 20, 2005 at 5:57 pm
    Hi Sean.
    When you duplicate an object, it links the original materials to the duplicated objects,
    as you’ve seen.
    To remove this link, do the following:
    1. Open the 3D Invigorator Set-Up Window
    2. Select a duplicated object
    3. Open the Object Styles tab in the upper-right corner of the Set-Up window
    4. Find the Swatch menu next to the Object Styles tab
    5. Select “Unlink Object Style”
    6. Repeat steps 2-5 for additional objects
    Your selected object(s) will now be independent of the original object, so you can
    specify a different object style or material for each one.
    Try the steps above and let us know if you need more assistance.
    Matt Rhodes
    Zaxwerks, Inc.
