Activity Forums Adobe After Effects Layer line when perpendicular
  • Layer line when perpendicular
    Posted by Fernando Mol on August 10, 2011 at 8:53 pm
    Hi, all
    I’m creating an animation of a flying witch following a 3D motion path. The witch is a 2D layer but I use the old trick of adding a second 2D layer of a top view of the same witch, so when it rotates it doesn’t look flat.
    My problem is that when any of the two layers appears perpendicular to the camera it draws a line. I hope this is not an unsolvable bug.
    Thanks in advance for your time.
    Fernando Mol replied 15 years, 1 month ago 2 Members · 2 Replies
  • Stefan Hinze
    August 10, 2011 at 9:34 pm
    i think this is only visible in the build, not in the render.
    to check, precompose it and look.
    greetz
    (take a step back, to see the bigger picture)
  • Fernando Mol
    August 10, 2011 at 9:40 pm
    It’s true, it doesn’t render.
