Activity Forums Adobe After Effects layer lenght
  • layer lenght
    Posted by Kurt Murphy on June 13, 2006 at 2:45 pm
    How do you extend a layer in AE 7? In previous versions you’d simply drag the end or move the timebar and Option]. Also, is there a pref to specify how long you want a PS file with layer to come in as a comp? The default is 2 frames and there’s NO pref for it to change it….
    thanks,
    kurt murphy
    Tim Kurkoski replied 20 years, 3 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    June 13, 2006 at 4:47 pm
    There’s no difference in how you change the length of a layer in AE7.
    If you can’t extend the length of a still image, what you might have is not a still image, but an image sequence. Check the Type column for the image file in the Project window. AE7 likes to turn on the “image sequence” checkbox in the Import dialog for any image it detects could be part of a sequence (ie., the folder contains numbered files), or you could also have turned on the checkbox for a single image. Re-import the single file with the checkbox off and you should be fine.
    BTW, to change the length of still images in a comp (regardless of their format), go to the Preferences > Import, and set the length in the Still Footage area.
