Activity Forums Maxon Cinema 4D Layer Hierarchy Issues
  • Layer Hierarchy Issues
    Posted by Eric Guiliani on February 15, 2016 at 4:48 pm
    Hello,
    Found a few threads on this but never a resolve. I’m using Cinema 4D Broadcast R17, and Cineware 3.0 with AE. The layers hierarchy seems to be messed up if all layers in a scene aren’t in the same root level:
    Fracture Object 1 ( green layer)
    Null Object Group within Fracture Object 1 ( red layer)
    Null Object Group Children (blue layer)
    If I turn layer visibility on/off for for the children of the main Fracture object in the layer manager (red or blue layers), nothing happens. Even when visibility is on for the Fracture Object green layer.
    Is there something I’m missing? I have tons of layers I need visible/not visible for a lower thirds titles project I’m doing. I have all of the titles in a null group, all within a main fracture object.
    Eric Guiliani replied 10 years, 7 months ago 1 Member · 1 Reply
  • Eric Guiliani
    February 15, 2016 at 6:59 pm
    In doing a little more research in C4d, I found that the hierarchy doesn’t work when you put everything in a fracture object. Is it known that layer hierarchy and visibility gets wonky once you place things into mograph objects?
