Activity Forums Adobe After Effects Expressions Layer following another with an offset in one axis
  • Layer following another with an offset in one axis
    Posted by Marc Hermitte on December 1, 2011 at 1:05 pm
    Hello! I’m pretty new to expression in AFX. I have this scene made of elements from a still that I took appart in Photoshop, each on Itès own layer. Some elements are the reflection of others, and I’d like to link them but have an offset only in the Y axis. As expression don’t “split” position in x, y and z, how can I modifiy this basic expression thisComp.layer(“BOOKS”).transform.position
    to make It work. If I try : thisComp.layer(“BOOKS”).transform.position*(0,-1.5,0) the expression isn’t invalided but works like the original one (same position) When I use : thisComp.layer(“BOOKS”).transform.position*-1.5, It works but the position get offseted in all the axis (x,y and z if 3d layer).
    Thank you!
    thisComp.layer("BOOKS").transform.position*(0,-1.5,0)
    Marc Hermitte replied 14 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 1, 2011 at 3:47 pm
    I think it’s going to look like this:
    p = thisComp.layer(“BOOKS”).transform.position;
    [p[0],-1.5*p[1],p[2]]
    Dan
  • Marc Hermitte
    December 1, 2011 at 3:49 pm
    Very cool! Thank you so much for your answer!!!
