Activity Forums Adobe After Effects Expressions Layer follow problem
  • Layer follow problem
    Posted by Sam Moulton on August 27, 2007 at 1:55 pm
    Ok so I’ve got this company timeline with kind of a tool tips window that follows along as a pointer moves. The problem is that I need to have the tool tips window stay put until the pointer gets to where it’s going. I control the X position of the pointer with a slider.
    Here’s the position code so far:
    y = value [1];
    val = thisComp.layer(“XSlider”).effect(“Slider Control”)(“Slider”);
    follow = val%100;
    if (follow > 9 < 10) { ease (follow, 9, 10, 0, 10) } else if (follow > 19 < 20) { ease (follow, 19, 20, 10, 20) } // a bunch of other else statements go here for 29 to 30 and so on up to 40 x = value + (follow * 10); [x, y] The problem I'm having is that the else statements don't seem to be working. my tool tips layer hangs at 0 until I get to 9 then smoothly moves from 9 to 10, but when the slider control gets to 19 nothing happens. The marks on the timeline are 100 pixels apart so I multiply the follow distance by 10 I'm probably missing something simple. Maybe this requires a logical operator.
    Sam Moulton replied 19 years ago 4 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    August 27, 2007 at 2:36 pm
    Play around with this:
    y = value [1];
    period = Math.floor(val/10);
    x = ease (val%10 +1, 9, 10, period*100, period*100 + 100);
    [x, y]
    Dan
  • Dan Ebberts
    August 27, 2007 at 2:47 pm
    Oops,
    I that one had an error. Try this:
    y = value [1];
    x = ease (val%10, 9, 10, period*100, period*100 + 100);
    [x, y]
    Dan
  • Sam Moulton
    August 27, 2007 at 3:04 pm
    Thanks, I’ll give that a try.
  • Sam Moulton
    August 27, 2007 at 3:36 pm
    here’s what I came up with
    val = thisComp.layer(“Control”).effect(“XPosition”)(“Slider”);
    offset = ease (val%10, 9, 10, period*10, period*10 + 100);
    x = linear (offset, 0, 100, 600, 0)
    I’ve redesigned the project a bit and am using the offset filter instead of position because of some 3D and scale issues.
    Everything works except that I can’t go above 100 on the slider.
    Thanks again for your help…
  • Mike Clasby
    August 27, 2007 at 6:04 pm
    Can you right click the slider number and reset the Max on the slider?
  • Sam Moulton
    August 27, 2007 at 7:18 pm
    got it figured out. Used the remainder function (%) to loop the slider value at 100.
    Now if I could just get the thing to work with negative numbers…. but that’s another project.
    here’s the working code.
    val = thisComp.layer(“PositionController”).effect(“xPosition”)(“Slider”)%100;
    offset = ease (val%10, 9, 10, period*10, period*10);
    x = linear (offset, 0, 100, 1, 6000)
    y = value [0];
    [x, y]
  • Lord Scales
    August 28, 2007 at 4:22 pm
    It has an error…
    y = value [0];
    [x, y]
    The variable y should be value[1], like this
    y = value [1];
    [x, y]
  • Sam Moulton
    August 29, 2007 at 3:39 am
    yup…. Just a type-0…
    Nice catch though
