Activity › Forums › Adobe After Effects › Layer Disappears during Render, but not during Ram Preview
Posted by Bob Tanner on November 18, 2011 at 5:58 amI’m exporting a composition and it plays back fine on RAM Preview, but when I export, one of the layers just disappears after 5 seconds when it’s supposed to stay in for 7 seconds… Anyone know what might be causing that?
ZevieJames Palugod replied 11 years, 6 months ago 4 Members · 4 Replies -
Ben G unguren
November 18, 2011 at 3:06 pmHard to say without looking at the project. However, there is a workaround: Set your comp to full-quality everything (full resolution, motion blur and frame blending enabled, etc), then press command/control with the Numeric 0 key to RAM preview — once the RAM preview is complete it will prompt you for a place to save the file. Then it will write an uncompressed (Animation codec) movie directly from the RAM.
Of course, this is a temp fix, but sometimes for smaller projects it can get you through.
Good luck!
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Walter Soyka
November 18, 2011 at 8:17 pm[ben g unguren] “press command/control with the Numeric 0 key to RAM preview — once the RAM preview is complete it will prompt you for a place to save the file.”
Great tip!
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
James Palugod
March 6, 2015 at 6:03 pmHi,
I had the same exact problem, Googled it and found this thread. In my comp the affected layer was a graphic I had on top of an iphone graphic layer. They layers were in the same z-space. I disabled motion blur for both layers and my comp rendered fine. Not sure how to fix if you need motion blur. Will share if I find out.
James
James Palugod
Producer, Shooter, Editor
http://www.doorbellmedia.com
