Activity Forums Adobe After Effects Layer dependencies are missing
  • Layer dependencies are missing
    Posted by Steven J casey on January 27, 2014 at 2:43 pm
    Worked on a project on my laptop, plugged into my desktop and getting the message about missing font family. The font is actually installed on both machines though so I can’t figure out why I’m getting this message. The font is called Blue Highway and it’s the “regular” style that seems to be missing. I actually reinstalled it again but still the error, and of course all my layouts are off. Is there something I can do to locate these “dependencies” without having to manually go through every layer? In this case that would be about 300 layers across 50 precomps.
    Steven
    Dell Precision T7500
    Intel Xeon CPU X5650 @ 2.67GHz 2.66 GHz (2 processors)
    60GB RAM
    Quadro 4000
    Windows 7 Ultimate
    CS6
    M-Audio FW 410
    Vegas Pro 12
    Joseph W. bourke replied 12 years, 7 months ago 2 Members · 4 Replies
  • Joseph W. bourke
    January 27, 2014 at 2:56 pm
    Steven –
    I just went through this very same problem a few days ago – although not with as many layer dependencies – the root of the problem lay in the fact that many fonts have the same name, but aren’t the same .ttf file. I reinstalled the necessary font on my new workstation, and got the same error you’re describing. It wasn’t until I tracked down the same filename download as my original on a different free fonts site that my problem went away. I hope this is your problem, because it’s much easier to solve than replacing every instance.
    I see several different Blue Highway fonts and families on several different websites, and they’re not in any way the same. Some are all caps, some are upper and lower case. Look on the machine which is working correctly, find the font in the Windows/Fonts folder on your C: drive. It may well be that the font name is something like 0024734.ttf, and not bluehighway.ttf. If you can do a search on that actual font name (if it differs from your new install) and find it, you’ve got the problem licked.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Steven J casey
    January 27, 2014 at 3:41 pm
    I’ll look into it. Thanks for your help!
    60GB RAM
    Quadro 4000
    Windows 7 Ultimate
    CS6
    M-Audio FW 410
    Vegas Pro 12
  • Steven J casey
    January 27, 2014 at 7:06 pm
    So I took the fonts off my laptop and installed onto the desktop only to have the same error. Is there a way to make AE find the correct font?? This makes no sense now that I’ve verified the exact font files are on both machines. Any help much appreciated!
    60GB RAM
    Quadro 4000
    Windows 7 Ultimate
    CS6
    M-Audio FW 410
    Vegas Pro 12
  • Joseph W. bourke
    January 27, 2014 at 10:22 pm
    Steven –
    Sorry that didn’t help. The only other thing I could find which might be useful is that in addition to the standard location, Windows/Fonts, Adobe also looks for typefaces in:
    Program Files\Common Files\Adobe\Fonts
    Maybe try swapping the font into that location, or looking to see if there might be a culprit font in there which is confusing After Effects.
    Joe Bourke
    Bourke Media
