Activity Forums Zaxwerks Layer Cycling Object
  • Layer Cycling Object
    Posted by Donovan Werts on January 28, 2008 at 12:17 am
    Hi, I’ve been reading the User Guide for ProAnimator. I don’t understand what Layer Cycling does, or how Illustrator layers work to make this happen. Morphing Objects sounds cool, does anyone have video samples online to see Layer Cycling, or perhaps can someone explain what is supposed to happen and what the Illustrator layers do? Thank you, Donovan
    Donovan Werts replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    January 28, 2008 at 1:05 am
    Hi Donovan,
    Check out this tutorial:
    https://library.creativecow.net/articles/okerstrom_jon/layercycle.php
    The concept is the same in Invigorator and in ProAnimator.
    Think of it as an electronic version of cell animation – or flip book animation. The idea is that each layer of Illustrator is one frame of the animation. Create a series of Illustrator layers where the elements move or change shape and you can make them move or morph in 3D in ProAnimator.
    Does this help?
    Jon
  • Donovan Werts
    January 28, 2008 at 5:35 pm
    Yes, that helps a lot. I’ll go through the tutorial and will understand it even more. Thanks so much for your reply, Donovan
