Layer Controls from a Master Composition
Hey all, I have been doing some research on trying to figure out how or if it is possible to control layers from 1 master composition.
Rough Example, I hope I can explain it well enough.
I have Master_Comp (inside) Comp1 (inside) Comp2 (inside) Comp3 (inside) Layer1, Layer2, Layer3, Layer4 etc….
Master_Comp
- Comp1 (Selected Layer)
-Comp2
-Comp3
-Layer1
-Layer2 (shy toggled)
-Layer3 (shy toggled)
-Layer4
Is it possible using a script if I have Comp1 selected I can edit the layers inside of Comp3, toggle shy on and off, opacity 100 / 0 etcThanks heaps
