Activity Forums Apple Final Cut Pro Legacy lay off HDV to min DV tape
  • lay off HDV to min DV tape
    Posted by Ceri Allen on June 30, 2010 at 5:05 pm
    Hi
    I am working on a mac G5 with a blackmagik card and FCP version 6.0.4
    I would like to lay off from FCP onto mini DV tape in HDV format. The timeline and the footage I am working on are all HDV.
    The deck I am laying off to is a Sony Digital HD videocasette recorder (HDMI).
    Please can someone explain the workflow to me for how to lay off in HDV, as far as I know I cannot do it through firewire as I would for a DV-PAL lay off.
    Ceri
    Jerry Hofmann replied 16 years, 2 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 30, 2010 at 8:07 pm
    What output ports does your black magic gear have? Does it have HDMI? What inputs does your deck have?
    FWIW, Firewire can put out HDV… it doesn’t automatically down convert it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Ceri Allen
    July 1, 2010 at 8:21 am
    Hi
    Blackmagik card has the analogue output which goes to a loom, and the SDI output.
    the deck has S video in, SDI video in and audio in.
    also has component out and HDMI out.
    I did try to output HDV through firewire but FCP only had options for firewire out at Pal 720×576 and the record mode option became greyed out on the deck when the VCR was set to HDV mode.
    Ceri
  • Jerry Hofmann
    July 1, 2010 at 3:08 pm
    The SDI out from Blackmagic should be able to send HDV ‘d think… to the SDI in of the deck.
    Jerry
