Lavalier Mic Buzz!
Posted by Rafi Bagramian on November 13, 2006 at 2:07 amI
Rafi Bagramian replied 19 years, 9 months ago 4 Members · 7 Replies -
Will Salley
November 13, 2006 at 6:56 amSounds like it’s a bad balancing circuit on the camera preamps. What model of camera? Are you using battery or power supply on the camera? Check cables and connectors!
System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
Rafi Bagramian
November 13, 2006 at 8:33 amPanasonic DVX-100A. I’m using Power. All other types of Mics work fine when hooked directly into the Camera! It’s only these Lavelier Mics!! Which, as I mentioned, work fine through the Mixer!!
I’ve tried different Cables!
Thanks.
Bouncing Account needs new email address
November 13, 2006 at 11:38 amYou know, you never told us which mics you have.
Sounds like an “open” shield on the mics or the camcorder.
Take all involved to a local technician and see that the tech can find,
Too little info at this distance.
Andrew Commiskey
December 2, 2006 at 12:14 amIs your Mixer battery or wall powered? Have you tried going on battery for everything? ground loops can come from anywhere and this includes anything hooked up to the camera and a wall outlet such as monitors, mixers, speakers, teleprompters etc.
Andrew
Chaos is the beginning of everything.
Rafi Bagramian
December 4, 2006 at 9:32 pmYes Andrew!! You got it!! I tried it with the Battery and there is no Buzz at all. Then I hooked it up to the power and the buzz came back!!!
I now recall I once did use it with the battery and had no problem. But I had forgotten about it.
Is there anything I can do to eliminate the Buzz when using the Power?
Thank you very much!!
Andrew Commiskey
December 4, 2006 at 9:44 pmMake sure everything that is pluged into the camera is on the same circut or try ground lifts (the ugly grey things that you plug onto extention cords to work in older houses). The ground lift is a last resort because it produces a few hazzards. Other things can be happening (I once had to deal with an alarm system in the floor that caused a buzz. We had to go all battery and the camera guy was not happy because his monitor was not battery operated. We would et up the shot then unplug the monitor to shoot.
*** Also dimmers on lights cause buzzes make sure they are on a different circut.
Good luck,
DrewChaos is the beginning of everything.
Rafi Bagramian
December 4, 2006 at 9:55 pmWell, no other item was being used! So that’s not it. And no dimmers either. So maybe I’ll try the Ground Lift and see if it works. If so, I’ll only use it if I can’t do it with the Battery.
Thanks again.
