Activity Forums Adobe After Effects Lava Lamp?
  • Lava Lamp?
    Posted by Ricardo Nichols on January 4, 2007 at 6:08 pm
    Anyone ever seen a tutorial that might help me figure out how to simulate a lava lamp effect?
    Or have any suggestions?
    Obviously the challenge is to create a amorphic blob that floats within a defined space….
    Is FOAM my best option?
    Any ideas are appreciated.
    Rolyn
    David Bogie replied 19 years, 8 months ago 5 Members · 4 Replies
  • Steve Roberts
    January 4, 2007 at 6:56 pm
    Try hitting “search posts” then doing an advanced search.
  • Serge Hamad
    January 5, 2007 at 12:05 am
    In case you have Invigorator, here is a project for you:
    https://www.nyc-visual.com/lava_lamp.sit
    Looks like this:
    https://www.nyc-visual.com/Lava_Lamp.mov
    If you don’t have Invigorator, still you should check the texture map to get an idea on how you could create the bubbles and distort them.
    Salut and have fun!
    Serge
    “InvigoMany” Available here:https://www.nyc-visual.com
  • Julian Sixx
    January 5, 2007 at 9:04 am
    Hi
    and if you want them to stick together and let go again you can do this with the Gaussian Blur and the Levels effect.Apply them to the adjustment layer>
    Blur amount = +/- 20
    Levels = Move all 3 triangles of the Alpha Channel to the middle
    it looks like this https://img518.imageshack.us/img518/2807/lavatexturemap0000713qx0.jpg
  • David Bogie
    January 5, 2007 at 3:07 pm
    Mr Mercury and Blobilize are good starts, too.
    bogiesan
