Lava lamp
Posted by Julian Sixx on November 5, 2006 at 11:50 amHi
how would you create a lava lamp with Invig?
Ref. Picture https://www.turbosquid.com/FullPreview/Index.cfm/ID/173201/SID/212851/blFP/1Custom edges?
What about the glass in the middle part?
Thx for any hintsJulian Sixx replied 19 years, 10 months ago 2 Members · 11 Replies -
Jon Okerstrom
November 5, 2006 at 2:47 pmHi Julian.
You could create the whole thing with one custom bevel applied to a circle from Illustrator. I would create slightly smaller copy of that shape to place inside the first, to simulate the inner wall of the glass.
I would then create another shape inside the lamp and layermap a movie of the lava blob to it.
Sounds like a fun project — we’d love to see what you come up with.
Jon
Julian Sixx
November 6, 2006 at 5:30 pmHi Jon
thanks for your tips .I will try it first without Custom Edges!How can i fake volumetric light in Invig.?
I created a solid with a mask and applied Shine and glow.I placed it 1Px in front of the Invig Layer.
It works as long as I don’t do any camera animations,after that the whole illusion is gone.Any ideas?
I tried parenting+expression but no luck so far.when i use the Blob video(with shine+glow) as a layer map it doesn’t glow at all.
I want the blobs to glow + shine. -
Jon Okerstrom
November 6, 2006 at 7:21 pmJulian:
Put the blob movie, glow and shine into a precomp, then make the precomp your layermap. That’ll force AE to render all three effects before applying the movie to your object.
As for volumetric light, I would suggest Trapcode Lux as one way to get it done.
Jon
Julian Sixx
November 7, 2006 at 5:24 amHi
I did the blob animation in a separate Comp and i use this comp as a layermap.
I’m not sure why a precomposed layer should work better than a nested comp.Does this only work with a precomposition?
[Jon Okerstrom] “That’ll force AE to render all three effects before applying the movie to your object.” -
Jon Okerstrom
November 7, 2006 at 2:20 pmHi Julian,
A precomposition and a nested composition are essentially the same thing… precomp is normally an AE term. Nested composition describes the same thing in Final Cut, Avid, etc.
The important part for you is whether the effects and settings are left applied to the layers inside the precomp or are applied to the precomp itself.
Jon
Julian Sixx
November 9, 2006 at 4:55 pmHi
Jon, would you mind creating a custom edge(like the one in the ref picture) as i’m not very familiar with Illustrator? -
Julian Sixx
November 10, 2006 at 4:57 amHi
If you could upload it with a webhoster and post the download link that would be great.
https://rapidshare.com/ -
Jon Okerstrom
November 10, 2006 at 1:33 pmTry this:
https://homepage.mac.com/jokerstrom1/FileSharing58.html
Please post a note letting me know you’ve downloaded it. I won’t leave the page up for ever.
Have fun.
Jon
