Activity › Forums › Adobe After Effects › Lava Lamp Effect
Lava Lamp Effect
Posted by Jonathan Pitzer on August 22, 2007 at 1:03 amI need a suggestion on how to create a Lava Lamp in After Effects. I thought that I would be able to find a tutorial but have been unsuccessful so far.
Aharon Rabinowitz replied 19 years ago 5 Members · 4 Replies -
Jerzy Drozda jr
August 22, 2007 at 1:50 amhey! i had this tutorial in my mind for a long time, but i thought about it as “Blob mesh”. i thought that it’s useless but it looks like someone really needs it. and Lava Lamp sounds much better so be ready. the tutorial is coming.
the basic idea is to draw the blobs, apply some turbulence if you wish, blur them quite a bit, and then apply alpha levels on the adjustment layer above them.
this may be not the exact recipe since i don’t remember how i did it when i was planning the tutorial, but since someone needs to know, i’m sure to check it out and record a new tut.
good luck.
cheers.
maltaannon.com – Free After Effects Video Tutorials and more
Rutger
August 22, 2007 at 2:08 amHello,
I think you can get pretty far with the CC Mr. Mercury effect. Requires quite a bit of tweaking though. A few tips:
– Set keyframes for birthrate to release a few blobs initially and then set it to zero.
– have the birth and death size set to the same value
– Set the influence map to “blob in” or “constant blobs”
– reduce the velocity to almost zero
– play with gravity to have the blobs go up and down (possibly have two or more layers to have up and down movement)
– reduce the ambient shading to get a nicer 3D effect
– Color it with your favorite color correction tool.Just some ideas,
Rutger
David Bogie
August 22, 2007 at 2:33 pmMr Mercury is a good suggestions but realize most AE filters offersno collision detection or rebound characteristics. Foam has a few but they’re not sophisitcated enough to create a lava lamp.
Best solution? Shoot it.
The heat-induced physics of the blobs (actually the same stuff with which you would make candles or use in home canning) is instantly identifiable as fake if created with a lowly particle generator.
bogiesan
Aharon Rabinowitz
August 22, 2007 at 9:18 pmOff topic – I just wanted to say thanks to Maltaannon for contributing so much to the Cow and to the AE community as a whole. Keep up the good work, man!
Best,
Aharon
Aharon Rabinowitz
arabinowitz(AT)yahoo(DOT)com
http://www.allbetsareoff.com—————————————-
Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
