Activity Forums Apple Final Cut Pro Legacy Launching FCP without media
  • Launching FCP without media
    Posted by Chris Heuer on August 4, 2010 at 12:38 pm
    I think I recall doing this before. I have an audio clip that I imported straight off of CD (as far as I can tell DON’T DO THIS!) Now when I launch the project (with or without the CD in the drive) FCP shows me the “Media Offline” dialogue, then gives me the Spinning Rainbow Wheel of Death.
    I would like to launch FCP without it trying to connect to the media, then remove this troublesome clip! Any help??
    Thanks, Chris
    Chris Heuer
    Freefall FX, LLC
    Jeremy Garchow replied 16 years, 1 month ago 2 Members · 3 Replies
  • Jeremy Garchow
    August 4, 2010 at 1:36 pm
    Is your footage on an external drive?
  • Chris Heuer
    August 4, 2010 at 2:42 pm
    The footage isn’t, just the music. I imported it from a CD. If the CD is out, FCP can’t find the media. I’m used to Avid which copies the file to your media drives when you import. Ooops!
    I trashed prefs using Larry Jordan’s instructions. All seems to be back in order. I have cut the old music file and imported a copy from my job folder. Can you launch FCP and have it not link to it’s media?
    I thought you could, but I may be confused with AE.
    C
    Chris Heuer
    Freefall FX, LLC
  • Jeremy Garchow
    August 4, 2010 at 2:57 pm
    [Chris Heuer] ” I imported it from a CD. “
    Meaning the media was playing off of a CD? Wow.
    [Chris Heuer] “Can you launch FCP and have it not link to it’s media?”
    Good question that I’m not quite sure of. If I need to do this, I usually just run off my raid, but it won’t help you in this case.
