Latest imacs and Firewire with Final Cut Pro
I have Final Cut Studio 2 on my brand new 27″ imac and my macbook pro. I have a Sony HVR-A1u and HVR-Z1u. Both work perfectly in FCP Studio 2 and digitize fine with HDV firewire settings on my macbook. However, my new imac has no firewire 400 in. Wow, Steve!! Anyway, It’s firewire 800 on the back.
I bought the Apple certified cable from the apple store to go from a firewire 400 mini to the port of the firewire 800 on the back of the imac. FCP does not see this camera or any camera. The port works with a firewire 800 drive, so the port is fine. The settings are precisely the same as my laptop that digitize from these two cameras. Again, everything works with my sony cameras on the macbook pro with the same software and same settings, but the macbook pro is firewire 400 (by the grace of God I can still digitize).
I am simply unable to digitize into FCP with my firewire 400 to firewire 800 cable from apple. I also bought a converter adapter, but that didn’t work either. Basically, I’m sitting here with a brand new 2K mac that can’t digitize video and has the same settings and hardware as my macbook pro. Wow!!
Anyone else have this problem, and if so, can you help? I have a feeling a hub will be a waste of time, and going through a workaround by plugging in this firewire 400 to 800 through a firewire 800 drive into the imac doesn’t work either.
Enough to make you scream. Man!
