Activity Forums Adobe Premiere Pro latest 2014 imac not supported
  • Kevin Monahan
    March 17, 2014 at 11:12 pm
    James,
    You can use that GPU even though it’s not certified. Any GPU over 1 GB VRAM can work. Just click through the warning dialog box. This explains it: https://blogs.adobe.com/premierepro/2013/06/adobe-premiere-pro-cc-and-gpu-support.html
    Kevin
    Kevin Monahan
    Online/Social Customer Success Lead DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Tim Kolb
    March 17, 2014 at 11:17 pm
    The cards didn’t make the “white list” at whatever point Adobe published it, but they may be too new…the 650M and 750M are on the list.
    CC version of Premiere Pro works with any GPU on the machine that meets minimum spec (1 GB RAM is a little meager, but it meets the minimum requirement).
    I suspect if there is some issue with the card’s functionality or a bug that seems to be specific to a card not on the “white list” Adobe just wouldn’t guarantee compatibility…but there are a LOT of users using cards not on the white list (CUDA or OpenCL). It’s far from unheard of…
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Ericbowen
    March 18, 2014 at 10:42 pm
    Media Encoder has a separate list last I checked so you would need to enable that GPU for the hardware acceleration on export.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Tim Kolb
    March 19, 2014 at 11:50 am
    [EricBowen] “Media Encoder has a separate list last I checked so you would need to enable that GPU for the hardware acceleration on export.”
    True…in CC, you’d want to track that text document down as well…
    TimK,
    Kolb Productions,
