Activity › Forums › Avid Media Composer › Last version of Avid – 2021.3
Posted by Doron Levene on April 18, 2021 at 8:01 amHello.
Upgraded today to the last version 2021.3
When trying to open the App, it crushes every time, before finishing reading and sorting all the bins in the project.
I had the 2020.10 installed before, and everything was running smooth.
I’m on Mac Pro (mid 2010) High Sierra 10.13.6
NVIDIA Geforce GTX 680 2048 MB
Memory 32 GB
Any help would be great (:
Doron Levene replied 5 years, 5 months ago 4 Members · 8 Replies -
Andrew Mckee
April 18, 2021 at 8:48 amHi Doron. I believe 2021 is only qualified for use on Big Sur. The last version I would recommend for High Sierra (I’m on an old MacPro too) is 2020.12.
Doron Levene
April 18, 2021 at 8:56 amHi Andrew (:
I’ve checked the documentations, it should support 10.13.6.
Pat Horridge
April 18, 2021 at 9:46 amWhat happens if you launch and create a new project
Or launch and create new user settings first.
Doron Levene
April 18, 2021 at 10:23 amHi.
Did try that, launching and creating a new project, didn’t seem to work unfortunately.
Will try out creating a new user, see if that helps.
Cheers.
Doron Levene
April 18, 2021 at 10:27 amNoop, doesn’t work… Crashes when I press enter for the new setting name.
Mike Drew
April 19, 2021 at 1:01 amHave you tried cleaning out all of the MCState files also you SHOULD NOT use settings from an older version as this will cause issues. Clear MCStates and use a new user.
HTH
Doron Levene
April 19, 2021 at 7:04 amHi Mike.
Found the those files, deleted them, tried to make a new user setting, and it still crushes 🙁
I think i’ll just re install the older version if i do’t hear form Avid support soon.
Thanks anyways.
