Activity › Forums › DVD Authoring › Last two chapter menu buttons not working. SOLVED!
  • Last two chapter menu buttons not working. SOLVED!
    Posted by Jack Vogel on December 24, 2015 at 5:23 pm
    SOLVED! Turns out I hit the 18 button limit. ARGH!
    DVD for a family member. I’ve built a chapter menu and the button to the last chapter doesn’t work when I test it. As far as I can tell there is no difference between the settings on this button and the others. The chapter is also marked in the time line just like the others (I wouldn’t be able to direct to it otherwise).
    Also the button to return to the main menu doesn’t work.
    To clarify the malfunction. They don’t behave like buttons in the demo menu. I can’t navigate to them OR activate them with the mouse. They also don’t change color when I mouse over. In the Flowchart however they indicate that they ARE linked correctly.
    Jeff Pulera replied 10 years, 9 months ago 2 Members · 1 Reply
  • Jeff Pulera
    December 28, 2015 at 3:06 pm
    You can can create multiple menu pages to get around the 18 button per menu limit. I routinely edit dance recitals with upwards of 40 acts and will use 3 or 4 menu pages to create buttons for each act.
    Jeff Pulera
    Safe Harbor Computers
