Activity Forums VEGAS Pro Last chapter of project is missing in DVDA
  • Last chapter of project is missing in DVDA
    Posted by Paul Gregory on January 10, 2013 at 5:20 am
    I rendered out a project in Vegas pro & imported it into DVDA for a Blu-ray project. Everything is perfect except for 1 thing the last chapter appears to be missing.
    The missing chapter can be see in DVDA on the timeline but the area is grayed out. When I click to load markers an icon for it appears on the SS menu. It’s linked to the button before it as well as up & down.
    If I go to project properties it gives me the files duration but this is about 1 minute shorter than whats on the timeline. I can even play the missing chapter on the timeline. How do I fix this?
    Thanks in advance
    Graham Bernard replied 13 years, 7 months ago 2 Members · 1 Reply
  • Graham Bernard
    January 10, 2013 at 2:02 pm
    When I’ve had this it is because I wasn’t careful about re-rendering and had used a little more of the Vegas Timeline, which ships into the already fixed DVDA Timeline and I did a Replace rather than a delete – if you understand where I’m coming from. Anyhoo . . What I needed to do was to Extend OR start over with a new Vegas render out and not do a replace in DVDA. Maybe just a delete in DVDA would do it for you?
    Grazie
    Cameras: Canon XF300 and two elderly XM2s
