Activity › Forums › Apple Final Cut Pro Legacy › Largest Video Codec Capture to 3x 1TB internal MacPro Stripe
Posted by Ryan Brooks on March 5, 2009 at 10:47 amHi there,
Apologies if this is badly worded.
What would be the Largest Video Codec that could be captured via FCP to 3x 1TB drives striped together internally in a MacPro?
Thanks.
Ryan.
Sean Oneil replied 17 years, 6 months ago 6 Members · 10 Replies -
Rafael Amador
March 5, 2009 at 12:28 pmHi Ryan,
is difficult to understand your question.
What do you mean, with which codec you could make the longest capture?
rafael -
Ryan Brooks
March 5, 2009 at 2:05 pmI think what Im saying is wht data rate could I get from this set up, for example: could I capture 10bit uncompressed HD to it (Probably not, but as an example).
Ryan.
Rafael Amador
March 5, 2009 at 2:46 pmHi Ryan,
OK now I understand.
I’m not an expert at all about Raids but I think that with the appropriated video card and computer your HDs won’t have problem for capturing 10b Unc HD.
However I guess that this also will depends in the way you strype your Hds.
rafael -
Steve Eisen
March 5, 2009 at 3:12 pmYou are going to need a minimum of 5 striped drives in a SATA or fiber enclosure to capture and edit Uncompressed HD. Oh yeah, you’ll need a AJA or Kona card also.
We’re not talking about the highly compressed XDCAM EX here.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Steve Eisen
March 5, 2009 at 3:17 pmEverything but uncompressed HD.
Steve Eisen
Board of Directors
Rafael Amador
March 5, 2009 at 3:42 pm -
Ryan Brooks
March 5, 2009 at 4:03 pmThanks for your help! I was only looking for a rough Idea of the Maximum capabilities of an internal stripe one of these systems.
Michael Sacci
March 5, 2009 at 7:08 pm10-Bit ProRes (HQ) can be recorded to and played back from a single SATA drive. With 3 drives stripped as RAID 0 you could get several streams (at least 3) playing back as a multicam seq. Pro Res (HQ) has the largest bitrate of any of the compressed codec used in FCP.
Media drives need to be kept under 80% full or they start to suffer with dropped frame issues.
Alan Okey
March 5, 2009 at 11:04 pmI’m able to capture, edit and play back a single stream of Uncompressed 1080i/60 without dropping frames using four internal SATA drives striped in RAID 0 (software RAID) in a Mac Pro. Boot drive is an external Firewire 800 drive. Not recommended for archiving or critical storage, however.
Sean Oneil
March 5, 2009 at 11:18 pmThe new tech that makes these drives larger also makes them faster. So I’m willing to bet 3x 2TB drives will be fast enough for Uncompressed HD.
But in a critical environment you don’t want to even cut it close. The drives will slow down as they get fragmented. You’re much better of going with an external SATA enclosure with 6 disks or more if you want to use U/C HD.
If your clientele does not pay well enough for you to afford such a paltry expense, you shouldn’t be giving them U/C HD anyways. Use ProRes as others here just mentioned.
Sean
