Large uncompressed VHS file to DVD. Advice needed.
For this project I need to transfer 90 minutes of uncompressed VHS footage onto DVD. I’ve captured the footage into Premier Pro CS6 using the ‘component out’ of a pro VHS deck (with built in TBC), into a AJA D5D Analog to SDI converter, and from there into an AJA IO Express. As you can imagine, the file size is rather large. I’m going to be using Adobe Encore CS6 to build the DVD. What would be the ideal settings for retaining as much of the original quality (or lack there of) of the uncompressed file. Should I transcode it in Adobe Media Encoder first or should I send it directly into Encore using dynamic link, and build the dvd from there? I will not be adding any menu’s or titles as this will be an “auto-play” dvd only. Thanks
