large size font edges are cut off!
Posted by Rafi Bagramian on December 7, 2006 at 12:54 amI
Rafi Bagramian replied 19 years, 8 months ago 3 Members · 5 Replies -
Rafi Bagramian
December 7, 2006 at 2:45 amI Picked a Text Size that fits the window, and then zoomed in with Pan/Crop and it worked, BUT! When I view it in
Mike Kujbida
December 7, 2006 at 3:13 amI’m assuming your text is within the Safe Title area.
If so, a text sizing trick I learned some time ago is to create it at double the default frame size.
That means changing it from 720 x 480 to 1440 x 960.
As long as you don’t zoom, it will still look the same in Vegas (probabbly a bit cleaner around the edges). Zooming in as you did is where the benefits of doing this show up 🙂
HTH. -
Rafi Bagramian
December 7, 2006 at 3:53 amYes! Your suggestion worked very well! Thanks!
But I just found out that the reason it was showing a distortion was because I had it Keyed to move across!! Once I took off the Keys it was fine!!! And when I rendered it (with the move) it was fine too!
Off course if I need the Text to fill the whole screen, then I
Edward Troxel
December 7, 2006 at 4:25 am
