Activity › Forums › Apple Final Cut Pro Legacy › Large Sequene Playback
Posted by James Whittington on November 5, 2008 at 11:53 pmHello,
I received a project from an outside edit house to do some further tweaks on. The project has 18 video tracks and 29 audio tracks. I am unable to play back the sequence back real time. It just stutters and pauses, etc. My computer is a fast one, but it just can’t do it.
What are the best ways to fix this?
Rafael Amador replied 17 years, 10 months ago 4 Members · 6 Replies -
Shane Ross
November 6, 2008 at 12:27 amWhat about the hard drive it is stored on? What type of drive do you have? I can do this fine on my setup. And I use an HD One to store my media. Firewire is definately out for this complex of a sequence. That is a LOT of streams of video.
Shane
Read my blog, Little Frog in High Def -
James Whittington
November 6, 2008 at 12:33 amAll my media is stored on an external 4GB drobo raid drive. It is hooked up to the tower via FW800. So maybe that is the problem?
Shane Ross
November 6, 2008 at 12:51 amYup…that’s it. DROBOs are for archiving, not to be used as Media drives. They are not fast enough…especially for what you are doing. The way the raid works is contra-indicative for video editing.
HA…used some big terminology there.
Shane
James Whittington
November 6, 2008 at 1:21 amI copied everything from the drobo to my internal 700GB media drive. It’s a little better, but still has a good amount of stuttering. Perhaps this project is just too big for my system? Any other ideas?
Thanks for your help!
Chi-ho Lee
November 6, 2008 at 2:22 amyou’ve neglected the most important information – what format is the media in???
-CHL
Chi-Ho Lee
Film & Television Editor
Apple Certified Final Cut Pro Trainer
http://www.chiholee.com -
Rafael Amador
November 6, 2008 at 3:20 amAnd even with low data rate media to move 18 video + 29 audio layers in RT is not that easy from an internal HD (I think).
Rafael
