Activity › Forums › Adobe After Effects › Large Motion Graphic Project: Workflow issues, do my layers have to be 3D layers?
  • Large Motion Graphic Project: Workflow issues, do my layers have to be 3D layers?
    Posted by Emily Burrow on May 27, 2012 at 10:08 pm
    The project that I am working on is going to be approx. 3 minutes long, and it has a load of elements that I use. If I had to guess I’m using about 50 or more. This makes the workflow a little tedious. I somewhat manage this by using the shy mechanic and colour labels.
    One of the problems I’m running into is when I precompose multiple 3D layers, I loose the composition and things disappear in z space. I will admit that this is my first large project and I am still testing out the waters. I continue to do more research to maximize my workflow, but one of the ideas I have had, is since my project is very linear, and none of the elements do any tricks in z-space, am I able to make all my element layers 2D to keep things organized and in the proper order? So then I would just keep my Camera and Null as 3D Layers to continue the camera movement? Would this work?
    I am also looking at some plugins that will help me manage all my elements, like SureTarget by VIDEOCOPLIOT
    Thanks for your time.
    Joseph W. bourke replied 14 years, 4 months ago 3 Members · 5 Replies
  • Erik Waluska
    May 28, 2012 at 4:11 pm
    When you pre-comp your 3D layers you can turn on the collapse transformations switch and the layers should return to their original 3D positions. Alternatively, depending on the project, you could pre-comp groups of 2D layers and then just turn on the 3D switch for that pre-comp. The difference is that with the first option the layers inside of the pre-comp remain 3D in the main comp so they can be individually rotated or moved in Z space, but with the second option all of the layers will basically become a flat 2D image that can be rotated or moved in Z space in the main comp as if it is a single 3D layer.
    HTH
  • Emily Burrow
    May 29, 2012 at 3:28 pm
    Thank you for your insight! I believe it will help me a lot.
    Thanks for your time,
    Em
  • Erik Waluska
    May 29, 2012 at 3:47 pm
    You’re welcome. Glad I could help.
  • Joseph W. bourke
    May 29, 2012 at 4:14 pm
    Emily –
    You may want to take a look at Zorro, as script for AE which gives you powers which far surpass the color coding and shy layers you’re using. Check it out:
    https://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&extid=1694092
    It’s free, but well worth a donation to the programmer.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Joseph W. bourke
    May 29, 2012 at 4:22 pm
    Just in case you didn’t go to the creator’s website, he’s updated Zorro to work with up to AE CS5.5:
    https://aescripts.com/zorro-the-layer-tagger/
    Joe Bourke
    Bourke Media
