Activity › Forums › Adobe After Effects › Large list of Credits question?
  • Large list of Credits question?
    Posted by Mark Weaver on July 12, 2005 at 9:13 pm
    Hello all,
    I was creating some credits with AE. I started by
    putting all the text into notepad and using tabs
    to format. Then I opened AE created a text layer and
    pasted the text into the layer. Everything worked fine
    except for a few typos and tab sizes.
    The wierd thing is that after the paste it took 30secs
    to delete or add a character from the text layer. Just
    hitting the backspace key would cause a wait(30sec) until
    the delete occured. Does this sound right? I have 2GB Ram
    and a P4 3.6GHz. I also noticed that this simple little
    scrolling animation took 1.25GBs during render, this seems
    like a lot just for a single layer render. (Fast Blur was
    the only effect added to the layer)
    Is there a better way to deal with long credit text layers?
    Thanks for any help
    Mark Weaver
    Mark Weaver replied 21 years, 2 months ago 2 Members · 4 Replies
  • Chris Smith
    July 14, 2005 at 12:26 am
    Definitely search the AE Cow archives under ‘credits’ or ‘Scroll’. It’s been asked many times.
    For my film I tried a few ways and settled on what I thought looked the best and was most efficient:
    1. In Illustrator create a very long document. Layout all your credits (not using tabs, but normal Illustrator ways of layout). Use a font that is thicker than thinner. Just do black text on normal BG.
    Import the .ai file into AE. Set it to continuosly rasterize. Create a white solid and put it below the text layer. adjust the Y layer position till the top of your text is just below the screen. Set a key. Go forward in the timeline to when you want your credits to end (like when your credit music ends) then set the add a – (negative) to the Y position to get you in the ballpark of getting the bottom of the credits positioned just above the top of the screen. Tweak as necessary. So now your credits should crawl and end when you set them.
    Now add an invert effect to the precomp so that it’s white on black. Then add a gauss blur set to vertical only or use a directional blur set to vertical and set the blur to around 2. This will help letters like capital ‘E’s from getting too weird with the scan lines.
    Also try turning on motion blur for your ai layer.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Mark Weaver
    July 14, 2005 at 1:23 am
    Chris,
    Thanks for the response, but does AE work better with a
    large AI layer than it does with a large Text layer? The
    motion for my credits is fine. I just can interact with
    the TEXT layer very easily because it takes 30sec to delete
    one character.
    Thanks for the note about AI, forgot about the progam. 🙂
    Mark
  • Chris Smith
    July 14, 2005 at 10:27 am
    Works just fine. But in my workflow, you just pop over to AI with your original document open and make a change. Save, then cmd-H it in AE to reload the file in place of itself in the project window then it updates in AE.
    Chris Smith
  • Mark Weaver
    July 14, 2005 at 7:18 pm
    Chris,
    Thanks for the knowledge… Time to start using
    AI again. 🙂
    Mark
