Activity Forums Apple OS X Large file transfer causes iMac to freeze/restart
  • Large file transfer causes iMac to freeze/restart
    Posted by Matt Whittemore on June 1, 2015 at 10:41 pm
    Hello,
    I couldn’t figure out the proper forum to post this in, as I don’t know if its an OS X issue, general file issue, etc. Please let me know if I should post in a different forum.
    I have some 4K footage from a GoPro. There are 2 files that, when trying to copy between external hard drives, cause my system to freeze, then restart. They get to 1GB then this happens. Other files are copying fine. These 2 open in QT just fine, but if I try to save them to a new location, export or duplicate, QT won’t do it. I’ve tried using MPEG Streamclip to export to mpeg-4 and it stops at 29%. Am I to assume these are corrupted? Any help would be greatly appreciated.
    Chris Smith replied 10 years, 7 months ago 3 Members · 2 Replies
  • Tristan Summers
    July 30, 2015 at 3:02 pm
    I am getting fails transferring large files from PC to Yosemite. I took hard drive out, put it in mac pro, and it worked fine. I think YoseVegemite might have problems with PC networking. If the footage you have is on an ExFat or ntfs drive, it could be this??
  • Chris Smith
    January 23, 2016 at 5:42 pm
    the problem is definitely with yosemite
