Activity Forums Apple Final Cut Pro Legacy large FCP project crashing, not reopening
  • large FCP project crashing, not reopening
    Posted by Jeffrey Mills on January 17, 2012 at 6:41 pm
    I’ve a very large FCP program (75 folders with approx 100 clips of EXCAM each) I successfully loaded everything, then started to log all the shots in the browsers description column. Got to a certain point, then tried to open it and it would not open successfully.
    I have a 2x3Ghz Quad Core with 8GB of memory. Am I at the limits of FCP (which is 6.0.6) or just at a memory deficit? I as able to load a saved version way back when all footage was loaded, but no logging notes. Every version close to the last won’t open.
    HELP!
    Jeffrey Mills replied 14 years, 8 months ago 3 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    January 17, 2012 at 7:46 pm
    How large is the project in MB? The project file size.
    Shane
    Little Frog Post
  • Jeffrey Mills
    January 17, 2012 at 7:54 pm
    About 59MB.
    Doesn’t make sense that this is too large. The only ideas I have is the addition of so much text in the description field (only barely into doing them all), or running out of RAM, or maybe a preference corruption. When I got the program to open once after several crashes, it didn’t show a timeline and it was greyed out the view choice. There had been one before.
  • Shane Ross
    January 17, 2012 at 7:56 pm
    That’s not too big. Hmmm. Any auto saves open?
    Shane
    Little Frog Post
  • Jeffrey Mills
    January 17, 2012 at 8:01 pm
    Yes, I went back to before adding text in the description column, and that opens and all links to media seem to be fine.
  • Jeffrey Mills
    January 17, 2012 at 11:21 pm
    Thought I’d add, even though I got a version to work, still puzzled at what happened and concerned it will recur as I start the edit, which will be a 1- hour doc.
  • Loic De lame
    January 17, 2012 at 11:27 pm
    Hello!
    Been itching to respond, but been having trouble with my cell network!
    I have been in that situation where a project file of mine became corrupt and even my autosaves were corrupt all the way up to the first one of the previous day.
    Unfortunately, I wasn’t able to find a way to recover the work I lost. And looking around online (this was somewhere like a year and a half ago or so), people were saying that they experienced the same problems, but with different sized files than what I had.
    For example, my project at the time was around 100MB and some people were saying that they had problems with projects that were like 50MB while others said they had projects that were 500MB!
    So, short answer is that unfortunately, there’s no real way out except to redo what you did.
    However, as a workflow method for your project, you can do the following to maybe help you out.
    Basically, what I did as a backup for myself at the end of the day, is to export an XML of my entire project. To do this, select the FCP browser window and make sure to not select anything (clips, bins, or sequences). Then do a File –> Export –> XML. Save it and back that up.
    The only thing I don’t know is if a corrupt project will translate/be exported into an XML. The project I was working on at the time was running smoothly the whole time and I had no indication that it was corrupt of any sort until the next day.
    I made a post of it and when I find the link I’ll post it. Good luck!
    Also, I’ve been curious about saving FCP project files to dropbox and using that as a backup method since it saves past versions. Maybe that can act as an “Autosave”. Of course, that’s dependant on you manually saving the project frequently. ;~)
  • Jeffrey Mills
    January 18, 2012 at 2:41 pm
    Thanks for the great suggestions Loic. I will be starting over, but not completely. I may take a different approach on viewing the bins. Rather than trying to add logging notes on all of the clips (7,5000 of them) I’ll try to view by small icon.
    This is something I’ve never done as I’m not crayz about how this workes in the browser- kind of clunky and hard to see spread over the page. Will this approach be a memory hog, or are these thumbnails always loaded every time you open a project whether you use them or not?
    This question goes back to one of my original concerns that I may not have enough RAM for this project (8 GB at present).
  • Loic De lame
    January 18, 2012 at 3:12 pm
    Hey.
    Glad I could be of help.
    To answer your question about RAM, you’re more than set. FCP can’t use more than 4GB of RAM max because it’s a 32bit application. So no problem there. Honestly, with my experiences with corrupt projects (up to now, 2 in the past 4/5 years), there’s nothing that can really explain it. Which is something that sucks about FCP; once the project is corrupt, oops….(one thing that is nice about Avid in comparison; the fact that it saves bins separately and you don’t loose everything).
    As for viewing bins, completely up to you. However, in adding notes, you can double click on folders that you’ve created to open them in a new window, which may help in managing your viewing.
    As for adding comments, it seems a bit awkward having to do it in a bin view. Of course, you can help yourself by moving the column to the left so you don’t have to open your window as wide.
    Also, another idea that just came to me is that you can load the clip in the viewer and add markers to the clips. The interest in that is that you can at minimum add a marker with a comment at the beginning of the shot. Or, you can go more in depth and add markers throughout the clip with a name and comment, splitting up the subject matter. This will also allow you to create subclips more easily if you decide to utilize that function. In addition, you’ll be able to go to the markers quickly by right-clicking on the timecode display of the Viewer (top right TC window) and you’ll see your markers by name at the bottom of the pop-up menu).
    Also, keep in mind that with markers, you can mark a range of time. The shortcut keys for markers are the ` (top left keyboard accent key) to make a marker and then Option-` to extend the end. If you hit ` over a marker, then it’ll enter the Edit Marker function where you can give the marker a name and then add comments. If you wanted to make a point-marker (so no range of time), you can quickly do so with M. Hit M after making a marker (or when you’re over an existing one) to enter the Edit Marker mode to create/change the name and comments. All these options are available in the Mark –> Markers menu, btw. But keyboard shortcuts are your friend. :~)
    One thing that can help you out, if you don’t know about this, is that you can make the text bigger. Go to Final Cut Pro –> User Preferences… and then in the General tab on near the bottom right above the Auto Render options, there’s Browser Text Size. Change that to whatever suits your needs and hopefully that’ll help.
    Post back and hope this helps!
    P.S. One this that I’m curious about is where this media is stored. Meaning is it on an internal hard drive or external? And if external, what’s the connection that you’re using? E.g. FW800, FW400, USB, eSATA, etc. And what format? SD/HD, etc.
    ~ Loïc
  • Jeffrey Mills
    January 18, 2012 at 4:40 pm
    Thanks once again. One other quick question on thumbnail view. Will I need to set a higher cache for so many clips? I’m assuming if I set the preference to view as thumbnail that it will apply to all bins simultaneously. Our can you just look at it that way for a single selected bin?
    As to your PS. My storage is a RAID array via PCIe on a CalDigit HDPro using Raid 5 (if I remember correctly).
  • Loic De lame
    January 18, 2012 at 5:06 pm
    Haha! Yeah….no problem with your hard drive setup. Wish I could get one of those…..oi…another story.
    For the bin views, looks like the thumbnail view forces you into opening windows for each bin you want to view. However, you can keep the browser in a detail view while your other bins are in thumbnail view. And, it looks like the bins remember the view that they are in. So you can open them in a seaparate window that’s a thumbnail view. Then, if you expand the bin in the browser window, it’ll be a list view. But double-click the bin in the list view, and it opens in a separate window in thumbnail view. Noice!
    As for setting the thumbnail cache, here are a few things.
    The way I setup my system is I put all the scratch disk preferences in System Settings on a drive other than the system drive. Obviously, that helps. If you wanted, you can put the Waveform, Thumbnail and Autosave on your HD Pro RAID. The autosave being the one that may be the exception since you may want it on another, completely separate drive from where your project and renders/media are.
    Now, as to another setting, which I believe you’ve touched on, is on the Memory & Cache tab of the System Settings. There, you can set the amount of space the Thumbnail Cache uses of the RAM. Keep in mind that the amount of RAM you allocate to the Thumbnail cache is taken from the Application Memory Usage (checked in the manual, Volume IV: Media Management and Output –> Part IV: Settings and Preferences –> Choosing Settings and Preferences –> Changing System Settings –> Memory & Cache tab; Volume IV Page 320). Also, I just checked on two of my systems and the FCP Application Memory Usage setting is limited to 2560MB.
    So, for the thumbnail cache in RAM, what you could do is if you’re logging, give it maybe 1/2 of the 2560MB. Or more. Then, when you move onto editing and such, reduce it a bit since you won’t need it as much. In either case, if the performance of FCP as a whole is degraded, this is a setting that you can adjust to get the best middle ground.
    Then, the Disk Thumbnail cache may be something you would want to look into possibly increasing. I don’t know myself how many thumbnails you can store in 8192KB. But making it a GB or 2 would probably be more than enough for all the clips you have. Something worth investigating I would imagine in your case.
    ~ Loïc
