Activity Forums Sony Cameras Large Ex1 file t
  • Large Ex1 file t
    Posted by Joel Roberts on July 19, 2012 at 1:30 pm
    Hi Guys, hope you can help.
    I have a large clip (20 mins long) which will not import straight into FCP7 vie log and transfer.
    I’ve extracted the file info from the SXS Card onto my Macbook an have ended up with a folder containing 5 files- .MP4, .SMI, .PPN, .XML, .BIM
    Can someone please explain how I can convert this into a .MOV so I can use it to edit in FCP7.
    Thanks in advance,
    Joel
    Michael Slowe replied 14 years, 2 months ago 7 Members · 17 Replies
  • 17 Replies
  • Puneet Malhotra
    July 19, 2012 at 1:42 pm
    hello Joel,
    A software comes from sony by the name, utility Softare for XDCAM, just search from google and you get it. download the latest version and it will browse the XDCAM files and footage from EX1 , EX3 cameras.it is the only way you can get EX 1 footage into FCP. the software itself makes .mov files when you import it from BAVP folder.
    puneetdnd@gmail.com
  • Don Greening
    July 19, 2012 at 2:31 pm
    Joel, if you want to avoid makIng things more difficult for yourself don’t mess with the contents of any BPAV folder. Under normal circumstances you will never need to view anything inside them.
    Sony has stand-alone products for converting XDCAM files to .mov format for FCP 7. They are XDCAM Transfer and the newer XDCAM Browser. The former is probably the easiest to use for the beginner but be advised that since XDCAM Transfer is considered a legacy program it may not work properly with the latest versions of the Mac OS.
    Do a Google search for these programs, which are free by the way, or go to any of the official Sony sites. If you run into trouble using them post back.
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Craig Seeman
    July 19, 2012 at 2:35 pm
    [Don Greening] “Joel, if you want to avoid makIng things more difficult for yourself don’t mess with the contents of any BPAV folder. Under normal circumstances you will never need to view anything inside them. “
    To use a simple analogy. Consider the BPAV your tape cassette. You’d never rip open the shell of a cassette to get at the tape, spool, etc. Open it up and risk damaging the contents. In this sense file media and tape are similar. Don’t try to outthink or over think it. When using XDCAM Browser always use CRC enabled so the copy is confirmed good.
  • Puneet Malhotra
    July 19, 2012 at 2:49 pm
    yes Joel, XDCAM browser from Sony is the only way to go for….
  • Joel Roberts
    July 19, 2012 at 3:12 pm
    Thanks for your quick responses guys,
    The thing is I do not have the actual SxS card itself or the camera. All I have is this folder of the above mentioned files. Will the transfer software still work with just these files?
    Also I have been to the Sony website and selected the software. It then takes me to another page which does not seem to have a ‘download’ option.
    Any further ideas or perhaps a direct workable link?
    Thanks again
  • Joel Roberts
    July 19, 2012 at 3:21 pm
    Ok, I think I have found a link for XDCAM Browser Software. Am downloading now so will let you know how it goes…
  • Joel Roberts
    July 19, 2012 at 4:25 pm
    Hi Don,
    Ok, I have downloaded the XDCAM Browser software and got the interface open. Now I have dragged the MP4 file into the preview window so I can see the clip that I need to use.
    All I want to do now is export the clip and turn it into a .MOV file so that it can be used in FCP7.
    PLEASE NOTE though that I do not have Final Cut on this machine as I am using my girlfriends Macbook. My Macbook is the other side of the country. All I really need is this file as a raw .MOV
    Any advise would be very welcome please please!!! Thanks
  • Craig Seeman
    July 19, 2012 at 4:34 pm
    [Joel Roberts] “All I really need is this file as a raw .MOV”
    MOV is a container not a codec. XDCAM Browser will wrap XDCAM EX in MOV but you would still need the codec to play it back in Quicktime or an NLE.
    If you need to transcode to another codec there’s some (expensive) plugins for XDCAM Browser or you will likely need an external encoder program of some sort.
    VLC will handle the XDCAM EX file in a pinch but it’s not a very good encoder IMHO.
  • Joel Roberts
    July 19, 2012 at 4:51 pm
    Thanks Craig,
    OK, so if I had FCP7 on the same machine could I import the file straight into that to be usable as a .MOV file?
  • Craig Seeman
    July 19, 2012 at 4:56 pm
    If you have FCP7 you’d have XDCAM EX codec. Otherwise you can buy a decoder from CalibratedSoftware.
    You could then use Apple Compressor to encode the XDCAM EX .mov to another codec such as Apple ProRes, Uncompressed 4:2:2 or H.264 .mov (if just for delivery).
