Activity Forums Adobe Premiere Pro Large Black Borders on Sequence
  • Ivan Myles
    August 7, 2013 at 3:53 pm
    Is this happening with all clips, or just clips from specific files? Here are some things to try:
    – Open the file in the Source Monitor to be sure the clip is not encoded with the borders.
    – Click on the clip in the timeline and check the scaling parameter under Motion settings.
    – Right-click on the clip and check whether Scale to Frame Size is enabled. Toggle it back and forth to see if it makes a difference.
  • Alexi Peck
    August 8, 2013 at 10:47 am
    It is in both timeline and exported. Everything is right in settings, but it still is the same
