Activity › Forums › Adobe Premiere Pro › Large AVI into Adobe Premier Pro 7
  • Large AVI into Adobe Premier Pro 7
    Posted by Poorboytree on October 2, 2006 at 1:55 pm
    I don’t know if its the file type, the size, or the formatting of it, but when I try to import an AVI file into premier it simply says importing files… and does nothing. My original task is to take 3 mini disc dvd’s from my bosses trip and combine them. Edit out some parts, such as the inside of his bag that went on for quite a while, and then create a new dvd that includes the pictures he also took with the dvd-r camcorder. I’m probably going about it the wrong way, so if anyone has a suggestion of how I should start let me know. I have no problems ripping the dvd files, or getting the images. I was even able to compile them into a avi file, but I’m having trouble authoring a new dvd. I thought I would be able to do that with premier, am I wrong? Alright thanks for the help, also if you need more information just ask, I’m new to this kind of work, I’m a computer tech not a video editor.
    Steven L. gotz replied 19 years, 12 months ago 4 Members · 3 Replies
  • Vince Becquiot
    October 2, 2006 at 3:29 pm
    Go download a free application called “GSpot”. Drag the file into it and it will tell us what the codec used for the file is.
    Vince
  • Chris Knight
    October 2, 2006 at 4:29 pm
    If you are importing files that were recorded on Mini DVD-R, you are better off using Adobe Premiere Elements 2, which supports that format natively. Premiere Pro gets a bit quirky around modern consumer camcorder formats.
  • Steven L. gotz
    October 3, 2006 at 1:46 pm
    When you rip the files you need to use AVI Type2 and not Type1. Does your software have that choice?
    Steven
    https://www.stevengotz.com
