Activity Forums Apple Final Cut Pro Laptop video playback stutter solved
  • Laptop video playback stutter solved
    Posted by Don Smith on January 20, 2012 at 9:26 pm
    When a friend showed me how her laptop was stuttering on video playback in FCPX I immediately started over-thinking the problem. In searching for the answer I found many posts on several forums with a similar problem but no solution. After two days, I awoke in the middle of the night and remembered that her laptop was older than mine and thus graphic card switching was not automatic as I had been assuming. Sure enough, in the Energy panel on her laptop, the battery-saving low-power graphics card was enabled. Prior to mid-2010, you had to manually change the graphic card selection and log out and log back in for the selection to take effect. Once I did the swtich for my friend, her laptop video playback returned to normal.
    NewsVideo.com
    Craig Seeman replied 14 years, 8 months ago 2 Members · 1 Reply
  • Craig Seeman
    January 21, 2012 at 12:25 am
    Interesting. You should send FCPX Feedback to Apple on this. I’d think it should be in their KBase.
