Activity Forums Adobe After Effects Laptop requirements
  • Laptop requirements
    Posted by Mycal Barrowclough on December 25, 2009 at 7:57 am
    Hey there. Just wondering if the specs on this laptop will be good enough to run After Effects cs4 relatively smoothly or not. Thanks in advance.
    Product Details
    Web Code: 10135252
    Mfr. Part Number: VGNNW265DW
    Base Features
    Approximate Battery Life Up To 4 Hours
    Hard Drive Speed/Capacity 320 GB (5400 RPM)
    LED Backlit Display No
    Optical Drive DVD±RW With Blu-ray Disc Playback
    Processor Speed 2.1 GHz
    Processor Type Intel Pentium T4300
    RAM 4 GB
    Screen Size 15.5″
    Graphics
    Discrete Video Memory No
    Expandable Video Memory Up To 1750 MB
    Graphics Chipset Intel GM45 Express
    Integrated Video Memory Yes
    Native Screen Resolution 1366 x 768
    Upgradable Video System No
    Video Memory 1750 MB
    Audio
    Audio Chipset Intel High Definition Audio
    Audio Output Stereo
    Digital Input Yes
    Digital Output Yes
    Hardware Volume Control Yes
    Integrated Amplifier Yes
    Integrated Microphone Yes
    Microphone Input Yes
    Speaker Wattage Information Not Available
    Speakers Yes
    Inputs/Outputs
    Card Reader Yes
    Card Reader – Compatible Memory Types MS Pro Standard/Duo; SD
    Composite Output No
    ExpressCard/34 Input Yes
    ExpressCard/54 Input No
    HDCP Compliant Yes
    HDMI Port Yes
    IEEE 1394 Input/Output 1
    IR Receiver No
    Number of Touchpad Buttons 2
    PC Card Input No
    S-Video Output No
    Type of Keyboard 86-Key Bilingual
    Type of Modem None
    Type of Pointing Device Electro-Static Touchpad
    USB 2.0 3
    VGA Output 1
    Webcam Yes
    Networking
    Ethernet Port 10/100/1000
    Integrated Bluetooth No
    Integrated WiFi 802.11 b/g/n
    Power
    Battery – Capacity 3600 mAh
    Battery – Number of Cells 6-Cell
    Battery Type Lithium-Ion
    Computing Features
    Processor Cache 1 MB L2
    System Bus 800 MHz Front Side Bus
    Software
    Loaded Software 1 VAIO Media Plus
    Loaded Software 2 VAIO Movie Story
    Loaded Software 3
    Loaded Software 4
    Operating System Language Bilingual
    Pre-loaded Operating System Windows 7 Home Premium 64-Bit
    Mycal
    Stephen Cordes replied 16 years, 8 months ago 3 Members · 2 Replies
  • Todd Kopriva
    December 25, 2009 at 7:26 pm
    Yep. That’s enough for basic work. (It’s close to what I have on my lap right now.)
    Don’t expect screamingly fast renders, and don’t try to use Render Multiple Frames Simultaneously multiprocessing for any but the simplest compositions.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Stephen Cordes
    December 28, 2009 at 9:41 pm
    Todd won’t that be rather slow? Shouldn’t he try and get a dedicated graphics card. The graphics card on that spec will take ram from the central CPU rather than using it’s own dedicated ram.
    You will probably get a lot better for you money. I have a T6600 dual 2 core with 4gigs ram and a ati radeon HD 4570 (albeit with a 15inch screen) and cost me just shy of £500.
