Activity › Forums › Adobe Premiere Pro › Laptop like audio
Laptop like audio
Posted by Spencer Tycksen on December 22, 2015 at 6:48 pmI need to put an audio filter on a track to make it sound like it is coming from a laptop. Any tips on how to create that effect?
Spencer Tycksen replied 10 years, 8 months ago 4 Members · 4 Replies -
David Roth weiss
December 22, 2015 at 9:07 pmThe easiest solution: record the audio playback from your laptop speakers on to your smart phone, then bring that into Premiere.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los AngelesDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Paul Neumann
December 22, 2015 at 11:23 pmIn Audition try Filter and EQ/FFT Filter/Telephone-Voicemail.
Ivan Myles
December 23, 2015 at 1:04 pm[Paul Neumann] “In Audition try Filter and EQ/FFT Filter/Telephone-Voicemail.”
A similar outcome can be achieved in Premiere Pro with a lowpass filter and adjusting the cut-off frequency.
Alternatively, if you want a “tinny” sound use the Equalizer Effect to reduce low frequencies and increase high frequencies. Also, if the source audio is stereo consider balancing the output to emulate mono.
