Activity Forums Creative Community Conversations Laptop as your main computer
  • Laptop as your main computer
    Posted by Oliver Peters on July 15, 2017 at 1:06 am
    Looking for opinions from those who have done the comparisons. Using a newish, loaded MBP as your main computer versus an older cheese grater MP. Figure the laptop would have an external display and some external drives. How would the MBP compare? FCPX? Premiere Pro? Resolve?
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Steve Connor replied 9 years, 1 month ago 10 Members · 18 Replies
  • 18 Replies
  • Andy Patterson
    July 15, 2017 at 1:43 am
    I used to edit with full tower computers until about 2002. In 2002 I started using mid towers. In 2005 I sold all my desktop computers and only used a laptop until about 2006. In 2006 HDV started to become popular so I invested in a desktop computer since the laptops really could not compete with the desktops for editing HD. For SD my laptop worked OK. Since 2006 we have seen AVCHD and Red One R3D files become popular. I think I will build my last desktop computer in another 5-6 months and in another 3-4 years from now I imagine the Tablet PCs will have 8 and16 core CPUs. There will not really be a need for a graphics card so why not get something really small and portable (tablet instead of a laptop). I plane on using a MS Surface Pro (or knock off) as my main editing system in another 3-4 years from now. I just don’t think the tablet PC or laptops can keep up with my desktop as of now. That should change soon now that AMD is offering some serious competition for Intel. I wonder if other people plan on using a Windows tablet as their main NLE in another 2-3 years from now?
  • Bill Davis
    July 15, 2017 at 2:41 am
    I suspect the modern MacBookPro would run rings around and Cheesegrater unless it was some hot-Rodded beast that somebody has sunk $$$ into in constant RAM/GPU upgrades.
    These modern Apple laptops Appear to be MUCH practically faster than their mere specs imply – at least running X. Apparently AVID and Premiere are simply not as optimized from everything I’ve read.
    Knowing Thomas Grove Carter reasonably well and having chatted with him a good bit and even watched over his shoulder as he’s cut on the road – it has appeared to me that he has NO performance issues of any kind while working on large/dense projects via his MacBookPro.
    Upgraded GPUs and big SSDs seem to make the largest difference in expanding laptop editing capacity – but when TGC was cutting live at NAB For his Supermeet demo – his totally stock MacBook Pro was crazy quick with the whole BMW and Ed Sheeran source pool on IIRC a 4TB External SSD.
    He’s had nothing but praise for the laptop approach when I’ve talked to him.
    You might expect stuff like long form to be more challenging – but my friends like Ryan and Mads at Metronome in Denmark have done tons of episodic TV on older iMacs that are barely faster than the latest MacBook Pros. Raids are the key there and AFAIK USB C/TB3 attach as easily to a MacBook as to an iMac.
    I’m sure processing or rendering out really massive layered rasters still requires all the processor grunt you can hook up to. So access to a shop style rig for mastering is maybe smart if you want to do big projects – but the editing really doesn’t seem to be a very big deal much anymore.
    I don’t do stuff that complex, only working regularly with 4K stuff for HD web delivery – not the big rasters or deep color stuff yet – but I doubt I’ll ever own another desktop rig.
    I’ve recycled too many big expensive CRTs and flat screens already over the years!
    YMMV.
    Creator of XinTwo – https://www.xintwo.com
    The shortest path to FCP X mastery.
  • Noah Kadner
    July 15, 2017 at 3:08 am
    I’d say if you’re used to Mac Pro performance, the 15 inch MBP + eGPU pretty much makes the case (so to speak). Even in High Sierra beta it’s pretty compelling. Just plan on dropping another $500-1000 for the enclosure plus a good card and then you’ll have the best of both worlds. Portability and desktop-grade firepower when you need to dock.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Andy Patterson
    July 15, 2017 at 4:13 am
    [Bill Davis]
    I’m sure processing or rendering out really massive layered rasters still requires all the processor grunt you can hook up to. So access to a shop style rig for mastering is maybe smart if you want to do big projects – but the editing really doesn’t seem to be a very big deal much anymore.”
    Unless you do over the shoulder editing for clients who want to see 6K or 8K at full resolution. Who knows in another 10 years we may have true hologram editing systems that will once again make me invest in a desktop computer until the mobile devices catch up.
  • Scott Witthaus
    July 15, 2017 at 12:24 pm
    Oliver –
    My MBP is my main system. I use, however, a Henge dock to clean things up. I then connect my Promise array to the dock, via Tb connection, and the monitor via the display connector. Mouse and keyboard via usb on monitor. These docks are not cheap, but using it, I rarely even think “I am editing on a laptop” because I never see the laptop and it cleans up my work area. Just a monitor, mouse and keyboard on my desk.
    https://hengedocks.com/pages/vertical-macbook-pro-retina
    Scott Witthaus
    Owner, 1708 Inc./Editorial
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Erik Lindahl
    July 15, 2017 at 1:43 pm
    I’d say it depends on what you do.
    For my workflow doing primarily TVC finishing a MacBook Pro would be a disaster, a nMP or Cheesegrader works much better. Then again I barely touch FCPX and primarily work in After Effects / Premiere / Resolve. For the latter, a MacBook Pro barely cuts it – heck my nMP 8-core / D700 often barely cuts it.
    So a laptop wouldn’t be a replacement. The current top-end iMacs come close as a viable solution, the coming iMac Pro might be a terrific option.
  • Erik Lindahl
    July 15, 2017 at 1:46 pm
    I could add for pure editing tasks a MBP would be fine. But in this scenario I’d rather go with an iMac. Faster, better screen and probably quieter.
  • Joe Marler
    July 15, 2017 at 2:03 pm
    [Oliver Peters] “Looking for opinions from those who have done the comparisons. Using a newish, loaded MBP as your main computer versus an older cheese grater MP. Figure the laptop would have an external display and some external drives. How would the MBP compare? FCPX?”
    I have a top-spec 2016 MBP, 2015 and 2017 iMac 27, and just finished testing a 12-core Mac Pro D700 on FCPX 10.3.4 and some on Premiere CC 2017.1.2. Below are some numbers. In general I greatly prefer a desktop machine to a laptop except where portability is absolutely required. Even with an external monitor for the laptop, the desktop is generally faster and quieter. That said, in one test my 2016 MBP was faster on FCPX than my 2015 top-spec iMac 27, but the 2017 iMac 27 was yet faster. For those who must do significant editing in the field, there are some good laptops.
    FCPX BruceX benchmark:
    iMac 27: 26.9 sec
    Mac Pro: 17.0 sec
    2017 iMac 27: 15.8 sec
    2016 MBP i7: 36.2 sec
    FCPX timeline render, Neat Video 4.5.5 NR on 31 sec XAVC-S 4k (after using Neat Video optimization to select best CPU/GPU combination):
    2013 Mac Pro (12 cores and 2x D700 GPUs used): 6 min 58 sec
    2015 iMac 27 (5 cores and M395X GPU): 9 min 7 sec
    2017 iMac 27 (7 cores and R9 580 GPU): 8 min 3 sec
    2016 MBP i7 (5 cores and Radeon Pro 460 GPU): 12 min 12 sec
    FCPX Import & create proxies for ten XAVC-S 100 mbps H264 4k files from Sony A7RII, total media duration 11 min 43 sec
    2015 iMac 27: 5 min 37 sec
    2017 iMac 27: 2 min 40 sec
    2016 MBP: 3 min 46 sec
    (I didn’t do this on the Mac Pro but other similar tests show it is 1.9x slower than the 2017 iMac i7 on this task)
    FCPX and Premiere CC: Export 1 min 51 sec 4k H264 XAVC-S media from timeline to single-pass 20 mbps H264 4k output
    FCPX, 2015 iMac 27 i7: 1 min 21 sec; CPU levels: moderate, noise & heat: low
    FCPX, 2017 iMac 27 i7: 1 min 8 sec; CPU levels: moderate, noise & heat: low
    FCPX, 2016 MBP i7: 1 min 24 sec; CPU levels: moderate, noise & heat: low
    Premiere, 2015 iMac 27 i7: 4 min 43 sec; CPU levels: high, noise & heat: high
    Premiere, 2017 iMac 27 i7: 4 min 11 sec; CPU levels: high, noise & heat: high
  • Oliver Peters
    July 15, 2017 at 2:13 pm
    Thanks. Those numbers are helpful.
    – Oliver
    Orlando, FL
  • Andrew Kimery
    July 15, 2017 at 4:41 pm
    What are the specs of the cMP and MBP? IIRC eGPU is only going to be officially supported via ThB3. Barefeats has lots of good comparisons between different Macs. https://barefeats.com/
