Activity Forums Apple Final Cut Pro Laptimer effect for fcpx
  • Laptimer effect for fcpx
    Posted by Matthew Avis on November 22, 2011 at 3:34 pm
    Hi Guys
    Hoping someone can help, i need to create a lap timer looking graphic to use in fcpx
    it will be a graphic placed in the top right corner of the screen and needs to be able to go unto 3minutes
    Im trying to create a counter that i can use to show each lap but only 1 lap at a time needs to be seen?
    I’m thinking a stopwatch type effect tried using motion 5 with an adapted timecode counter but its not working that well
    any ideas?
    Matt
    Bill Davis replied 14 years, 10 months ago 2 Members · 2 Replies
  • Bill Davis
    November 23, 2011 at 8:25 pm
    X has a generate time code function built in.
    (in the Generators area under Elements)
    Pop it over black (or anything you like) then crop, range and export it as a separate element you can re- use to your hearts content.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Bill Davis
    November 23, 2011 at 8:27 pm
