Activity Forums VEGAS Pro Lagarith – Cineform – Uncompressed – WMV tests
  • Lagarith – Cineform – Uncompressed – WMV tests
    Posted by David Timar on August 7, 2007 at 10:39 pm
    Hello everybody!
    During the last months I did many tests for conversion/cross-conversion reasons, and I thought I would share all my facts with those looking for such
    information.
    The original sources were raw M2T files, recorded at 720p@50fps with a JVC GY-HD201E.
    Software used: Sony Vegas 7.0d, Lagarith codec, Cineform NEO 2K, Windows XP 32bit PRO
    GENERAL INFO
    Lagarith stores 24bit images
    Cineform and Uncompressed stores 32bits
    COLOR VALUE CHANGES
    I took the M2T and converted/cross-converted it into various formats, then comparing the images and the color values on the video scope in Vegas.
    Since Uncompressed and Lagarith are considered lossless, it was Cineform’s compression I was interested in.
    1. BETWEEN Lagarith AND Lagarith->Uncompressed (0.01% color difference)
    2. BETWEEN Uncompressed AND Lagarith->Uncompressed (0.01% color difference)
    3. BETWEEN Lagarith AND Uncompressed->Uncompressed (0.01% color difference)
    4. BETWEEN Uncompressed AND Uncompressed->Lagarith (0.01% color difference)
    5. BETWEEN Lagarith AND Cineform (0.20% color difference)
    (DIFFERENCE WHEN VIEWING THE VIDEO IS NOT VISIBLE TO THE VIEWER)
    6. BETWEEN Uncompressed AND Cineform (0.20% color difference)
    7. BETWEEN Cineform->Lagarith AND Cineform->Uncompressed (0.03% color difference)
    8. BETWEEN Cineform->Lagarith AND Lagarith->Uncompressed (0.20% color difference)
    9. BETWEEN Cineform->Uncompressed AND Lagarith->Uncompressed (0.20% color difference)
    Conclusion: there is no visual difference between any of the above cross-conversions from M2T.
    FILE SIZES
    30 sec raw m2t=72MB
    30 sec raw m2t converted into cineform in sony vegas = 319MB (setting Medium HD)
    30 sec raw m2t converted into lagarith in sony vegas = 659MB
    SMALL FILE CINEFORM TEST
    I converted a 5 sec raw M2T file to Cineform AVI in Sony Vegas and got the following file sizes with these settings in Cineform:
    – Low: 134MB
    – Medium: 139MB
    – High: 151MB
    – Higher: 85.7MB
    Exported the same M2T file from Sony Vegas to Lagarith, and it came to 148MB.
    Visually, there are no differences between any of the above formats.
    NEO 2K test
    I had another 30 sec M2T file. It was 72MB RAW.
    I converted this to:
    – Cineform (Higher HD) in Sony Vegas: 384MB
    – Cineform (High) AVI in HDLINK: 327MB
    – Cineform (High) MOV in HDLINK: 326MB
    – Cineform (FilmScan) AVI in HDLINK: 327MB
    PROBLEMS WITH NEO2K
    As soon as anything passes through HDLINK, the colors change dramatically, as if it jumped from Studio RGB to Computer RGB. I found no solution to this.
    ARCHIVING SOLUTION
    After all these, due to the software (Sorenson Squeeze) used by my client, we had to revert to WMV to archiving.
    I did a Windows Media test:
    RAW M2T: 76MB (30sec)
    Converted to Lagarith: 664MB (frame size 1280x860px)
    Converted to Cineform (Higher HD): 435MB (frame size 1280x860px)
    WMV 10MBPS (CBR 2 PASS): 43MB
    WMV 20MBPS (CBR 2 PASS): 85MB
    WMV 30MBPS (CBR 2 PASS): 126MB
    WMV 30MBPS (CBR 2 PASS): 154MB
    WMV 50MBPS (CBR 2 PASS): 178MB
    We decided that a 20MBPS WMV is ideal for archiving, as there seem to be no visual deterioration from M2T to WMV.
    I am kind of a test freak, so I will be posting more of my tests later on, hopefully with more explanation…
    David
    Bill Clotz replied 19 years ago 4 Members · 4 Replies
  • Terry Nahirny
    August 7, 2007 at 11:12 pm
    David thankyou for the post!! That helps me today. I just did more test burns using Vegas capture vs. Cineform conversion and found no difference to my eye. The Cineform files were huge and my laptop did not like them in Vegas 7e. I’m not nearly convinced about Cineform at this point -unless anyone can figure out why it’s not working for me.
    Thanks again for the post David and love to hear more of your tests!!
    t.
  • Douglas Spotted eagle
    August 8, 2007 at 12:13 am
    You’ll find a bigger difference with CineForm when you go to push color, composite, etc. If you’re merely doing cuts only or light transitions, then CineForm vs native HDV likely isn’t of serious value to you.
    Douglas Spotted Eagle
    VASST
    Aerial Camera
  • Terry Nahirny
    August 8, 2007 at 12:34 am
    I’ll do some tests on that now DSE, tks.
  • Bill Clotz
    August 8, 2007 at 2:04 am
    If there is even a 0.01% difference in Lagarith -> Lagarith or uncompressed -> Lagarith, then there must be some sort of bug in whatever software you are using for the conversion or the measurement :p
    Lossless means lossless. 0% difference.
