Activity Forums Adobe Premiere Pro Lag when adjusting scale and position on still images
  • Lag when adjusting scale and position on still images
    Posted by Matt Chapman on June 26, 2017 at 12:49 pm
    Hello-
    I’m creating a rough animation (storyboard animatic), using the latest version of Premiere CC 2017.1.2
    The animatic is around 11 minutes and 550 PNG panels at 1920 x 1080.
    I am using a decently spec’d MAC PRO CYLINDER and OSX.
    When I adjust the POSITION or SCALE of an image there is a significant lag on the preview image. As I recall the last time I used Premiere for this sort of thing there was no lag.
    It makes it quite difficult to create the animatic because many panels need to be re-sized or panned, and the size change is not 1:1, so you can’t really eyeball things, or you have to wait for the preview to catch up.
    ‘Thanks
    MC
    Does anyone know what could cause
    Mark Whittle replied 9 years, 1 month ago 2 Members · 1 Reply
  • Mark Whittle
    June 28, 2017 at 9:37 am
    Are your png source files 1920×1080?
    What size is your sequence and what are your sequence settings?
    Try changing the playback quality from full to half to see if that makes a difference.
    Sounds odd for a mac pro to struggle with that.
    Mark W.
