Activity › Forums › AJA Video Systems › Lag Moving Clips on Timeline in Premiere
Chris Holland replied 14 years, 10 months ago 7 Members · 11 Replies
Chris Holland
October 20, 2011 at 12:48 pmWell I’ve read that switching to Lion fixes it but if you are using a Kona LHi card then you can’t monitor SD and if you try to change your playback settings Premiere crashes.
We have 3 Macs here all the same except 2 of them are running Lion. None of the other 3 have this problem but both with Lion have the crashing issue when trying to adjust playback settings.
HD seems fine on Lion but you still can’t adjust the sequence playback settings in Premiere.
Chris Holland
Editor/Animator
