Activity › Forums › Adobe Premiere Pro › Lag moving clips in the timeline
Mihai Wilson
July 31, 2011 at 12:49 pmThanks for that tip! This was driving me bonkers — hope everyone is telling Adobe about this issue, Its kept me away from Premiere for a while now.
Tom Daigon
July 31, 2011 at 4:03 pmSo Mihal, have you told Adobe about the problem. If you dont, you reduce the probability that the problem will be fixed. Tell them here…
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Tom Daigon
Avid DS / PrP / After Effects Editor
http://www.hdshotsandcuts.com -
Sney Noorani
December 20, 2013 at 4:00 amholy crap, you’re right this does improve the issue greatly….yet fills me with even more scorn for Premier… I use it, but I loathe it…
James Lee
February 10, 2014 at 2:20 pmWow, I just had this for days.
I had my 24GB of memory set up for single core rendering because it was faster in rendering time as I had low cpu intensive renders.
Bottom line was my GUI was not getting enough CPU love. So I turned on the multiprocessing. I needed to make the Actual CPUs part get to max by adjusting Zero for other apps and lowering the RAM allocation per background CPU until the Actual got to max.
I goes much better now.
