Activity Forums Apple Final Cut Pro Legacy lacie drives
  • Posted by Rick Broat on June 13, 2006 at 1:42 am
    I have 2 250gb lacie drives both 7200 rpm – 1 is a usb 2.0 and 1 is a firewire 400 and 800. When I try to digitize to the usb 2 drive i can’t – dropped frame error message keeps popping up. when i digitize to the firewire drive (using the 800 cable] all is fine. Does the usb 2 drive need a different setting? My input setting is dv ntsc. my device control options in drop down menu under capture settings are all firewire choices. any suggestions. running fcp 5.0 on powerbook g4 w 2 gigs ram. digitizing from dv cam tr22. thanks
    John Calhoun replied 20 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • Simon Carlson-thies
    June 13, 2006 at 1:46 am
    You have hit the biggest problem of USB… USB2.0 may have a fast spec but in all honesty FW 400 and 800 are better… personally I have a similar situation on my laptop… I use the firewire one for video capture and USB2.0 for a scratch drive and incremental small backups.
    The issue comes down to USB2.0 is not fast enough with overheads… to support video capture…
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Rick Broat
    June 13, 2006 at 1:57 am
    thanks – thought usb 2 would work…. I will try to copy media to the usb drive,(it is the porshe design and much more portable) and edit from there…. if that will work.
  • David Slater
    June 13, 2006 at 4:52 am
    NO USB 2 will NOT work reliably as it doesn’t have fast enough sustained thoughput
    use firewire
    DAVE at Movies Rock in Toronto
    June 13, 2006 at 6:50 am
    for a scratch disk it does, unless your doing HD… not for capture there you are correct…
  • Rezyser
    June 13, 2006 at 11:20 am
    hello, i had a different problem with USB 2.0 disk. when compressing audio to AC3 using Compressor 2 i was always getting anoying noise in the whole track. it doesn’t happeen on FW800. i never had any problems with dropped frames. i do edit DV PAL on powerbook g4 1,33 with 768mb ram.
    June 13, 2006 at 3:16 pm
    Are you changing the sampling rate… ie going from 44.1khz to 48.0khz?
    Since this problem is not necessarily a HardDrive problem…
  • Rezyser
    June 13, 2006 at 4:38 pm
    the audio rate was good, it never happens when i’m using internal drive or FW800 as scratch disk, only on USB 2.0 (i know it sounds strange and it’s an unprofessional diagnosis, but it just happens ;-))
  • John Calhoun
    June 13, 2006 at 4:50 pm
    Your problem is more fundamental which doesn’t really have to do with sustained throughput.
    USB devices are asynchronous, which means that any device has the power to send any amount of data at any time. If two devices decide to talk at once, their data can collide with each other. If the traffic
  • David Bogie
    June 13, 2006 at 5:38 pm
    CAUTION: Joke follows:
    > asynchronous, which means that any device has the power to send any amount of data at any time.< That sounds like a sustained throughput problem to me and, frankly, anyone with dropped capture frames can understand that, even if it's not literally true. > One is asynchronous, the other is isochronous mode (signal delivery capability at a specified rate), and guarantees continuous bandwidth without interruption. < As much as we'd love to use this juicy information, it's easier to say "USB doesn't have the sustained throughput required for video." But I swear I'll try to stop using sustained throughput. I shall substitute, erm, "USB2 refuses to respect time-sensitive data flow whereas Firewire has the emotional capacity to deal with such sensitivities." bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • John Calhoun
    June 15, 2006 at 3:36 pm
    Although “it’s easier to say ‘USB doesn’t have the sustained throughput required for video'”; that doesn’t explain why. I had to clarify because two posts said that USB ‘wasn’t fast enough’, which is technically not true. That’s why people get confused by the different specifications and applications of USB and Firewire. As professionals we try to avoid wasted time and wasted money.
    Plus, for crying out loud, it’s not really covered in the freakin’ manual. ;
