Activity Forums Apple Final Cut Pro Legacy LaCie Drive Trouble
  • LaCie Drive Trouble
    Posted by Eeandtee on June 23, 2005 at 7:25 pm
    hi
    i just bought a lacie big disk hard drive
    i have a pb g4 1.67 1 gb and fw 800 port
    i followed directions to start up the drive and it mounts
    the problem is that it is constanstly plugging itself in out!
    i get error messages every 30 seconds warning me that the device was not ejected before it was unplugged! but i didnt touch the thing!
    what is going on and help me stop it!!!
    ef
    Walter Biscardi replied 21 years, 2 months ago 4 Members · 4 Replies
  • Walter Biscardi
    June 23, 2005 at 11:18 pm
    Did you erase and re-initalize it before starting to use it?
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Fran Michelle
    June 24, 2005 at 7:42 pm
    If the drive has a USB port, try connecting through that see if you have a similar problem.
    A friend of mine had to return a LaCie because it had a bad Firewire bus. He encountered the same thing – the drive kept unmounting & re-mounting itself.
    Just a thought.
  • Ivan George
    July 1, 2005 at 3:36 am
    I own 5 lacie disks including the 500 gig disk. I’ve had nothing but problems. Lacie BLOWS!
  • Walter Biscardi
    July 1, 2005 at 11:26 am
    [Ivan Yousif]
    I own 5 lacie disks including the 500 gig disk. I’ve had nothing but problems. Lacie BLOWS!”
    Very professional statement there. LaCie is a rock solid device when used properly and maintained properly. I’ve been running the Big Disk Extreme for over a year with everything from DV to 10bit uncompressed with no issues. The units move around from system as needed and have not had a hiccup.
    Are the problematic LaCie products out there? Sure, but show me one drive manufacturer that doesn’t. It’s a piece of hardware, it will fail, especially if it’s not taken care of properly.
