Activity › Forums › Apple OS X › Lacie D2 500gb copy and paste issue
  • Lacie D2 500gb copy and paste issue
    Posted by William Hynes on April 4, 2008 at 5:20 pm
    I’ve been having an issue with transferring my files from my Macbook Pro to my new Lacie 500gb drive. I can see the drive and the contents in the drive, but when I start to transfer files over the drive goes into a sleep like state and the copying symbol just stops transferring. I thought it might had been a corrupted file, but I have a 1tb Lacie drive and that works fine. I drive isn’t set to sleep, but it doesn’t like me transferring files onto the disk. Help please!
    Simon Carlson-thies replied 18 years, 5 months ago 2 Members · 1 Reply
  • Simon Carlson-thies
    April 10, 2008 at 8:41 pm
    Sounds like a bad enclosure… first run disk utility if possible then if you have access to another enclosure try that.
    Also you may try a different connection method if you can….
    Simon Carlson-Thies,
    Complex Technology Development
