Activity Forums Storage & Archiving LaCie 12TB 4Big Quadra External Hard Drive RAID Array
  • LaCie 12TB 4Big Quadra External Hard Drive RAID Array
    Posted by Mark Laslo on December 13, 2011 at 3:55 pm
    Hi All,
    Sorry if this is a redundant post, I tried to search out similar threads but didn’t have much success.
    I am looking into purchasing the LaCie 12TB 4Big – https://www.bhphotovideo.com/c/product/753279-REG/LaCie_301562U_12TB_4big_Quadra_External.html as well as their controller card – https://www.bhphotovideo.com/c/product/604392-REG/LaCie_713113_4_Port_eSATA_II_PCI.html
    The function of this drive will be to edit using FCP with as well as final storage for finished products. I will also be backing up completed projects to a separate 2 TB time capsule so that if the whole unit fails everything isn’t lost.
    My questions are
    1. I’m working with Final Cut Pro using 1 – 3 streams of Pro Res 422, will this be fast enough to handle that in a RAID 5 configuration
    2. Is there a way to control the drive using the card I linked to or do I have to use the onboard controller and just get a regular eSATA card.
    3. Any other suggested products for under $1700. DIY can be an option.
    Thank you for all of your help,
    Mark
    Mark Laslo replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
