Activity Forums Apple Final Cut Pro Legacy label Inconsistency
  • label Inconsistency
    Posted by Kimberly on May 11, 2005 at 12:25 am
    Working in FCP HD 4.5, various G5s, OSX 10.3.9 on a documentary series…
    We are using labels to identify clips with various footage house sources (to determinte show costs)
    As we continue to cut, labels (as set in the browser) fail to be reflected in the timeline. This makes counting our footage from the timeline based on color impossible. In tests, the labels seem to hold up fine in smaller projects but reliably fail (on various systems) when used on the hour-long episode.
    Any known bugs, workarounds, or suggestions?
    David Bogie replied 21 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 11, 2005 at 1:54 am
    There’s a small triangle button (fifth button over from the left side on the bottom of the Timeline Window) you need to click on to reveal the option to show clip lables in the Timeline window… must be turned on. Is it?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Bogie
    May 11, 2005 at 2:16 pm
    Labels do work properly. Implementing them proper is a user error either based on not activating the display or trying to apply them to clips in the Browser and expecting them to appear on user-defined independent clips in the timeline.
    bogiesan
