Activity Forums AJA Video Systems LA-No communication
  • LA-No communication
    Posted by Scott G on April 5, 2006 at 7:41 pm
    I’m using an LA box w/ a UVW1800 and can not get communication in log/capture mode w. FCP 5.0.4.
    I was logging, stepped away from the machine for 20 minutes and when I went back there was no communication!
    The deck is in remote, there a re no other firewire connections,I have trashed preferences, I can see the video in the log/capture window if I flip the deck into mannual and play it, but I can’t control it.
    So the question is what is it, the LA box, the deck, the cable? Any suggestions would be very helpful. Thanks
    Mike Weber replied 18 years, 3 months ago 3 Members · 2 Replies
  • Bob Zelin
    April 5, 2006 at 10:53 pm
    did you cycle power on the I/O LA, and reboot your MAC ?
    I am always amazed at the miracle cures by simply cycling power, and reseating the Firewire cable.
    bob Zelin
  • Mike Weber
    May 14, 2008 at 10:17 pm
    I had this same problem, and your solution (power down/power up AJA box) fixed it for me. Thanks Bob!
