Activity Forums Blackmagic Design Kristian: DL SP PCIe – NTSC Monitor
  • Kristian: DL SP PCIe – NTSC Monitor
    Posted by Ponyboy on August 25, 2006 at 5:14 pm
    Kristian,
    Since you’ve been answering my posts I thought I’d direct this one to you. Anyway, I finally received my NTSC monitor (Sony PVM-14L1) yesterday. I connected the “SDI Monitoring” cable to the video input and the “SPDIF monitoring” cable to the audio input. I configured After Effects 7 to preview using Blackmagic Video output but I still cannot see anything on my Sony monitor. Any suggestions? Thanks in advanced.
    System configuration:
    Mac Pro, Quad 2.66, 2GB RAM, 1 TB media HD, 2×23″ Cinema Display
    Decklink SP PCIe with universal binary beta installed (Decklink_5_71)
    OS 10.4.7, Final Cut Studio, After Effects 7 Pro
    Ponyboy replied 20 years ago 2 Members · 2 Replies
  • Kristian Lam
    August 26, 2006 at 6:42 am
    The SDI output is digital. Chances are that your monitor does not support SDI video. Try using the one labelled Y output instead if the input of your monitor is just a single BNC and switch the output video option in the DeckLink Preferences to “NTSC/PAL Y-Out”
    As for audio, SPDIF is also digital. You’ll need to convert the digital audio output to analog audio. One option is the M-Aduio Flying Cow converters. Alternatively, the Edirol MA-10D which accepts SPDIF audio is a nice and low cost option.
    regards
    Kristian Lam
    Blackmagic Design
  • Ponyboy
    August 27, 2006 at 2:48 am
    It worked! You rock Kristian. Thanks.
