Activity › Forums › AJA Video Systems › Kone Wont see FCP
  • Kone Wont see FCP
    Posted by Dan Archer on January 22, 2007 at 10:38 pm
    I know this is a stupid question. My Kona Lhe wont see FCP. It outputs bars to my monitor so i know it is alive. I belive there is one switch or selection in FCP that lets me control wht my kona sees. Any help would be appreciated. and yes I am cross posting this to FCP. Thanks
    Walter Biscardi replied 19 years, 8 months ago 2 Members · 3 Replies
  • Walter Biscardi
    January 22, 2007 at 11:13 pm
    [Lecherro] “I know this is a stupid question. My Kona Lhe wont see FCP. It outputs bars to my monitor so i know it is alive.”
    It works the other way around. FCP sees the Kona.
    Be sure you have your Video Output set up to play out through the Kona (Audio / Video Settings) and be sure your External Video is set to All Frames.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Dan Archer
    January 22, 2007 at 11:29 pm
    I found it. I am still getting used to the conversion from Avid. Thank you.
  • Walter Biscardi
    January 22, 2007 at 11:41 pm
    [Lecherro] “I found it. I am still getting used to the conversion from Avid. Thank you.”
    Be sure to read through the Kona manual. The setups are very well explained in there.
